Failed to set TCP MD5 password option because of invalid password length or remote address type.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Warning
Failed to set TCP MD5 password option because of invalid parameter. Password length = %p1% Remote address type = %p2% Socket address type = %p3%
Name | Type |
p1 | uInt32 |
p2 | uInt8 |
p3 | sInt32 |
